Créer et insérer une progress bar dans une macro
Bonjour à tous !
J'aimerais créer et insérer une macro dans le code ci-dessous car cette macro prend un certain temps à s'exécuter et cela pourrait laisser penser à l'utilisateur que CATIA a planté.
Si quelqu'un a une solution je suis preneur merci d'avance !
Option Explicit
Public MyMergedAreasCollection As Collection
Public ExcelExportFile As String 'Chemin complet du fichier Excel d'export
Private Function Row_Col_IntegerConversion(MyRow As Integer, MyCol As Integer, MyNbCol As Integer) As Integer
Row_Col_IntegerConversion = (MyRow - 1) * MyNbCol + MyCol - 1
Private Function CreateDrawTabCell(iRow As Integer, iCol As Integer, MyTable As DrawingTable, ListOfmergeCells()) As DrawTabCell
Dim MyCell As DrawTabCell
Dim MytableVBS As Object
Dim MyTestCell As DrawingText
Dim MyTextProperties As DrawingTextProperties
Dim MyMergedArea As MergedArea
Dim MyNbCol As Integer
Dim MyfirstRow As Long, MyfirstCol As Long, RowLg As Long, ColLg As Long
Set MyCell = New DrawTabCell
Set MytableVBS = MyTable
Set MyTestCell = MyTable.GetCellObject(iRow, iCol)
Set MyTextProperties = MyTestCell.TextProperties
Set MyMergedArea = New MergedArea
MyNbCol = MyTable.NumberOfColumns
With MyCell
.row = iRow
.column = iCol
.merged = ListOfmergeCells(Row_Col_IntegerConversion(iRow, iCol, MyNbCol))
.value = MyTestCell.Text
.fontname = MyTextProperties.fontname
.fontsize = MyTextProperties.fontsize
.bold = MyTextProperties.bold
.italic = MyTextProperties.italic
.underline = MyTextProperties.underline
.alignement = MyTable.GetCellAlignment(iRow, iCol)
End With
If MyCell.merged = 1 Then
MyTable.GetMergeInfos iRow, iCol, MyfirstRow, MyfirstCol, RowLg, ColLg
If MyfirstRow = iRow And MyfirstCol = iCol Then
With MyMergedArea
.firstRow = MyfirstRow
.firstCol = MyfirstCol
.RowLg = RowLg
.ColLg = ColLg
End With
MyMergedAreasCollection.Add MyMergedArea
Set CreateDrawTabCell = MyCell
Private Sub Write_Excel(MyExcel As String, NbRow As Integer, NbCol As Integer, MyCellsCollection As Collection, MyMergedAreasCollection As Collection)
Dim ObjExcel, ObjWbooks, ObjSheet
Dim iRow As Integer, iCol As Integer
'Création de l'objet Excel
Set ObjExcel = CreateObject("Excel.Application")
'Désactivation des messages erreurs liés à Excel
ObjExcel.Application.DisplayAlerts = False
'Définition et sauvegarde du fichier Excel d'Export
Set ObjWbooks = ObjExcel.Workbooks.Add
ObjWbooks.SaveAs Filename:=ExcelExportFile, FileFormat:=51
Set ObjSheet = ObjExcel.ActiveWorkbook.Worksheets(1)
Dim MyCurrentCell As DrawTabCell
ObjSheet.Range(ObjSheet.Cells(1, 1), ObjSheet.Cells(NbRow, NbCol)).NumberFormat = "@"
For Each MyCurrentCell In MyCellsCollection
ObjSheet.Cells(MyCurrentCell.row, MyCurrentCell.column).value = MyCurrentCell.value
With ObjSheet.Cells(MyCurrentCell.row, MyCurrentCell.column).Font
.Name = MyCurrentCell.fontname
.Size = MyCurrentCell.fontsize / 0.36
Select Case MyCurrentCell.underline
Case 1
.underline = 2
Case Else
.underline = -4142
End Select
.bold = MyCurrentCell.bold
.italic = MyCurrentCell.italic
End With
Select Case MyCurrentCell.alignement
Case CatTableTopLeft
.VerticalAlignment = -4160
.HorizontalAlignment = -4131
Case CatTableMiddleLeft
.VerticalAlignment = -4108
Case CatTableBottomLeft
.VerticalAlignment = -4107
Case CatTableTopCenter
.HorizontalAlignment = -4108
Case CatTableMiddleCenter
Case CatTableBottomCenter
Case CatTableTopRight
.HorizontalAlignment = -4152
Case CatTableMiddleRight
Case CatTableBottomRight
End Select
End With
Next MyCurrentCell
For Each MyMergedArea In MyMergedAreasCollection
ObjSheet.Range(ObjSheet.Cells(MyMergedArea.firstRow, MyMergedArea.firstCol), ObjSheet.Cells(MyMergedArea.firstRow + MyMergedArea.RowLg - 1, MyMergedArea.firstCol + MyMergedArea.ColLg - 1)).merge
' Sort the data using the fourth column as the sorting key
ObjSheet.Range(ObjSheet.Cells(4, 1), ObjSheet.Cells(NbRow, NbCol)).Sort _
Key1:=ObjSheet.Cells(3, 4), Order1:=2, Header:=1, _
OrderCustom:=1, MatchCase:=False, Orientation:=1
ObjExcel.ActiveWorkbook.Save
'Reset de l'objet Excel et des messages d'alertes Excel
ObjExcel.Quit
ObjExcel.Application.DisplayAlerts = True
Set ObjExcel = Nothing
Dim MyDocument As Document
Dim InputObjectType(0), oListOfmergeCells()
Dim MyTable As DrawingTable
Dim MyCellsCollection As Collection
Dim NbRow As Integer, NbCol As Integer, sizeTab As Integer
Dim ExportFilePath As String
Dim MySelection As Selection
Dim MySelectionVBS As Object
Dim Status
If Not Is_ActiveDocument_Draw Then
MsgBox "Un Drawing doit être ouvert", vbExclamation
End
Set MyDocument = CATIA.ActiveDocument
Set MySelection = MyDocument.Selection
Set MyCellsCollection = New Collection
Set MyMergedAreasCollection = New Collection
Set MySelectionVBS = MySelection
InputObjectType(0) = "DrawingTable"
Status = MySelectionVBS.SelectElement2(InputObjectType, "Sélectionner la Drawing Table à exporter", True)
If (Status = "Cancel") Then
MsgBox "Tâche annulée", vbInformation
End
Set MySelection = MySelectionVBS
Set MyTable = MySelection.Item(1).value
ExportTabDrawFrom.Show
NbRow = MyTable.NumberOfRows
sizeTab = NbRow * NbCol
ReDim oListOfmergeCells(sizeTab - 1)
MytableVBS.GetCellsMerge oListOfmergeCells
For iRow = 1 To NbRow
For iCol = 1 To NbCol
MyCellsCollection.Add CreateDrawTabCell(iRow, iCol, MyTable, oListOfmergeCells)
Next iCol
Next iRow
Write_Excel ExcelExportFile, NbRow, NbCol, MyCellsCollection, MyMergedAreasCollection
' Récupérer le chemin du fichier Excel exporté
ExportFilePath = ExcelExportFile
Select Case MsgBox("Export Terminé" & Chr(10) & "Fichier Excel d'export sauvegardé sous:" & ExtraireChemin(ExcelExportFile) & vbCrLf & "Voulez-vous ouvrir le dossier d'export?", vbYesNo + vbQuestion)
Case vbYes
ShellExecute 0, "OPEN", ExtraireChemin(ExcelExportFile), "", "", 3
End Select
MsgBox "Importation"
' Appeler la fonction ImportExcel avec le chemin du fichier exporté
ImportExcel ExportFilePath
Create_DrawingTable
Keisukke- timide
» inserer une étiquette
» macro et automation
» Trier une listebox (MACRO tri Arbre de Construction CATIA)
» Macro cartouche
» enregistrement macro
» Macro cartouche
