Importation des points d'un profil d'aile à l'aide d'une macros Excel
J'essaie d'importer les points d'un profil d'aile à partir d'excel en exécutant une macros. Le fichier excel avec lequel je travail est
Mais il me donne l'erreur suivante :
Cordialement.
GSD_PointSplineLoftFromExcel
Incompatibilité de type
StartLoft
StartCurve
0 100.005600 0.125900
0 99.852400 0.154300
0 99.393800 0.239100
0 98.632400 0.378800
0 97.572900 0.571100
0 96.221500 0.812800
0 94.586400 1.099900
0 92.677500 1.428000
0 90.506100 1.792200
0 88.085400 2.187100
0 85.430100 2.607300
0 82.556300 3.046800
0 79.481400 3.500100
0 76.224200 3.961100
0 72.804600 4.423900
0 69.243600 4.882600
0 65.562900 5.331000
0 61.785100 5.763000
0 57.933600 6.172300
0 54.032000 6.552700
0 50.104600 6.897900
0 46.175400 7.201800
0 42.269100 7.458400
0 38.409700 7.662200
0 34.621400 7.808200
0 30.927600 7.892200
0 27.351600 7.910700
0 23.915600 7.861500
0 20.641000 7.743500
0 17.548300 7.556900
0 14.656800 7.303000
0 11.984600 6.984400
0 9.466100 6.600100
0 6.931300 6.009100
0 4.789500 5.213000
0 3.046600 4.298000
0 1.698300 3.337800
0 0.734400 2.391400
0 0.141000 1.502900
0 -0.097900 0.701000
0 0.000000 0.000000
0 0.406100 -0.578700
0 1.090100 -1.025500
0 2.028600 -1.362600
0 3.196000 -1.619600
0 4.565500 -1.832600
0 6.109800 -2.041200
0 7.804700 -2.286200
0 9.632200 -2.608200
0 11.974800 -2.986300
0 14.632500 -3.313600
0 17.506900 -3.584900
0 20.580500 -3.799100
0 23.834600 -3.956600
0 27.249300 -4.058500
0 30.804000 -4.107200
0 34.476900 -4.105800
0 38.245800 -4.058500
0 42.087500 -3.969800
0 45.978600 -3.844600
0 49.895400 -3.688100
0 53.813900 -3.505400
0 57.709900 -3.301600
0 61.559400 -3.081500
0 65.338800 -2.849400
0 69.024800 -2.609400
0 72.594400 -2.365300
0 76.025600 -2.120400
0 79.297100 -1.877800
0 82.388500 -1.640500
0 85.280600 -1.411400
0 87.955200 -1.193200
0 90.395600 -0.988400
0 92.586600 -0.799900
0 94.514200 -0.630200
0 96.166400 -0.481600
0 97.532800 -0.356500
0 98.604600 -0.257000
0 99.375100 -0.184600
0 99.839300 -0.140600
0 99.994400 -0.125900
EndCurve
EndLoft
End
Cordialement.
Monsrhf- timide
Re: Importation des points d'un profil d'aile à l'aide d'une macros Excel
J'ai apportée quelques petites corrections dans la fonction "GetCATIAPart()"
Pour que la macro fonctionne, il faut avoir une Part active dans CATIA.
' Get CATIADocument
Function GetCATIAPart() As Object
Set CATIA = GetCATIA
Dim MyPart As Object
'*********** début correction: *******************
'Set MyPart = CATIA.ActiveEditor.ActiveObject
Set MyPartDoc = CATIA.Activedocument
Set MyPart = MyPartDoc.Part
'************ fin correction *********************
Set GetCATIAPart = MyPart
Monsrhf aime ce message
Merci @lumpazepfel pour votre réponse. Permettez moi de vous demander, car je suis un novice sur VBA, où est ce que je vais insérer ce code est ce que dans le fichier excel où il y a le code ci-haut ou dans l’Éditeur VBA ?
Cordialement.
Cordialement.
Monsrhf- timide
Oui le code a modifié se trouve dans l’éditeur VBA de Excel : cliquer sur (1)"Développeur" puis sur (2)"Visual Basic".
Ensuite dans l'éditeur VBA cliquer sur (3)"Déclarations" et rechercher (4) "GetCATIAPart" puis corriger la fonction comme indiqué dans mon message précédent.
Ce que vous avez posté ce n'est pas un code, ceux sont les valeurs que la macro va importer dans CATIA.
les lignes StartCurve et EndCurve permettent de séparer les valeurs pour créer des courbes différentes en une seule fois.
Attention, je pense qu'il ne faut pas laisser de ligne vide.
j'ai suivi les étapes indiquées ci-dessus, mais le problème persiste toujours. Il indique le même message d'erreur "incompatibilité de type".
Le code par défaut que j'ai trouvé dans l'éditeur VBA est comme suite :
Cordialement.
' Get CATIADocument
Function GetCATIAPartDocument() As Object
Dim MyPartDocument As Object
Set MyPartDocument = CATIA.ActiveDocument
Set GetCATIAPartDocument = MyPartDocument
' Creates all usable points from the parameter file
Set MyPart = MyPartDocument.Part
Cordialement.
Monsrhf- timide
Poster le code en entier, ce sera plus facile pour le tester de mon coté.
Quelle est votre version de CATIA?
J'ai la version V5R21 de Catia. Le code en entier est comme suite :
Cordialement.
Mounssif
'// COPYRIGHT DASSAULT SYSTEMES 2001
'// Generative Shape Design
'// point, splines, loft generation tool
Const Cst_iSTARTCurve As Integer = 1
Const Cst_iENDCurve As Integer = 11
Const Cst_iSTARTLoft As Integer = 2
Const Cst_iENDLoft As Integer = 22
Const Cst_iSTARTCoord As Integer = 3
Const Cst_iENDCoord As Integer = 33
Const Cst_iERRORCool As Integer = 99
Const Cst_iEND As Integer = 9999
Const Cst_strSTARTCurve As String = "StartCurve"
Const Cst_strENDCurve As String = "EndCurve"
Const Cst_strSTARTLoft As String = "StartLoft"
Const Cst_strENDLoft As String = "EndLoft"
Const Cst_strSTARTCoord As String = "StartCoord"
Const Cst_strENDCoord As String = "EndCoord"
Const Cst_strEND As String = "End"
'To define the kind of elements to create (1: create only points
'2: creates points and splines
'3: Creates points, splines and loft
Function GetTypeFile() As Integer
Dim strInput As String, strMsg As String
choice = 0
While (choice < 1 Or choice > 3)
strMsg = "Type in the kind of entities to create (1 for points, 2 for points and splines, 3 for points, splines and loft):"
strInput = InputBox(Prompt:=strMsg, _
Title:="User Info", XPos:=2000, YPos:=2000)
'Validation of the choice
choice = CInt(strInput)
If (choice < 1 Or choice > 3) Then
MsgBox "Invalid value: must be 1, 2 or 3"
Wend
GetTypeFile = choice
'Get the active cell
Function GetCell(iindex As Integer, column As Integer) As String
Dim Chain As String
Sheets("Feuil1").Select
If (column = 1) Then
Chain = "A" + CStr(iindex)
ElseIf (column = 2) Then
Chain = "B" + CStr(iindex)
ElseIf (column = 3) Then
Chain = "C" + CStr(iindex)
Range(Chain).Select
GetCell = ActiveCell.Value
Function GetCellA(iRang As Integer) As String
GetCellA = GetCell(iRang, 1)
Function GetCellB(iRang As Integer) As String
GetCellB = GetCell(iRang, 2)
Function GetCellC(iRang As Integer) As String
GetCellC = GetCell(iRang, 3)
'Syntax of the parameter file
'StartCurve -> to start the list of points defining the spline
' double , double , double
' double , double , double -> as many points as necessary to define the spline
'EndCurve -> to end the list of points defining the spline
'Example:
'StartCurve
' -10.89, 10 , 46.78
'1.56, 4, 6
'EndCurve -> spline composed of 2 points
Sub ChainAnalysis(ByRef iRang As Integer, ByRef X As Double, ByRef Y As Double, ByRef Z As Double, ByRef iValid As Integer)
Dim Chain As String
Dim Chain2 As String
Dim Chain3 As String
Chain = GetCellA(iRang)
Select Case Chain
Case Cst_strSTARTCurve
iValid = Cst_iSTARTCurve
Case Cst_strENDCurve
iValid = Cst_iENDCurve
Case Cst_strSTARTLoft
iValid = Cst_iSTARTLoft
Case Cst_strENDLoft
iValid = Cst_iENDLoft
Case Cst_strSTARTCoord
iValid = Cst_iSTARTCoord
Case Cst_strENDCoord
iValid = Cst_iENDCoord
Case Cst_strEND
iValid = Cst_iEND
Case Else
iValid = 0
End Select
If (iValid <> 0) Then
'Conversion string -> double
Chain2 = GetCellB(iRang)
Chain3 = GetCellC(iRang)
If ((Len(Chain) > 0) And (Len(Chain2) > 0) And (Len(Chain3) > 0)) Then
X = CDbl(Chain)
Y = CDbl(Chain2)
Z = CDbl(Chain3)
iValid = Cst_iERRORCool
X = 0#
Y = 0#
Z = 0#
' Get CATIA Application
'Remark:
' When KO, update CATIA registers with:
' CNEXT /unregserver
' CNEXT /regserver
Function GetCATIA() As Object
If CATIA Is Nothing Then
Set CATIA = CreateObject("CATIA.Application")
CATIA.Visible = True
Set GetCATIA = CATIA
' Get CATIADocument
Sub CreationPoint()
'Get CATIA
Dim PtDoc As Object
Set PtDoc = GetCATIAPartDocument
' Get the HybridBody
Dim myHBody As Object
Set myHBody = PtDoc.Part.HybridBodies.Item("GeometryFromExcel")
Dim iLigne As Integer
Dim iValid As Integer
Dim X As Double
Dim Y As Double
Dim Z As Double
Dim Point As Object
iLigne = 1
'Analyze file
While iValid <> Cst_iEND
'Read a line
ChainAnalysis iLigne, X, Y, Z, iValid
iLigne = iLigne + 1
'Not on a startcurve or endcurve -> valid point
If (iValid = 0) Then
Set Point = PtDoc.Part.HybridShapeFactory.AddNewPointCoord(X, Y, Z)
myHBody.AppendHybridShape Point
Wend
'Model update
PtDoc.Part.Update
' Creates all usable points and splines from the parameter file
'Limitations:
' ============================> NO MORE THAN 500 POINTS PER SPLINE
Sub CreationSpline()
'Limitation : points per spline
Const NBMaxPtParSpline As Integer = 500
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim iRang As Integer
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
Dim index As Integer
Dim PassingPtArray(1 To NBMaxPtParSpline) As Object
Dim spline As Object
Dim ReferenceOnPoint As Object
Dim SplineCtrPt As Object
iValid = 0
iRang = 1
'Analyze file
'reinitialization of point array of the spline
index = 0
'Remove records before StartCurve
While ((iValid <> Cst_iSTARTCurve) And (iValid <> Cst_iEND))
ChainAnalysis iRang, X1, Y1, Z1, iValid
iRang = iRang + 1
Wend
If (iValid <> Cst_iEND) Then
'Read until endcurve -> Spline completed
While ((iValid <> Cst_iENDCurve) And (iValid <> Cst_iEND))
iRang = iRang + 1
'valid point
index = index + 1
If (index > NBMaxPtParSpline) Then
MsgBox "Too many points for a spline. Point deleted"
Set PassingPtArray(index) = PtDoc.Part.HybridShapeFactory.AddNewPointCoord(X1, Y1, Z1)
myHBody.AppendHybridShape PassingPtArray(index)
Wend
'Start building spline
'Are there enough points ?
If (index < 2) Then
MsgBox "Not enough points for a spline. Spline deleted"
Set spline = PtDoc.Part.HybridShapeFactory.AddNewSpline
spline.SetSplineType 0
spline.SetClosing 0
'Creates and adds points to the spline
For i = 1 To index
Set ReferenceOnPoint = PtDoc.Part.CreateReferenceFromObject(PassingPtArray(i))
' ---- Version Before V5R12
' Set SplineCtrPt = PtDoc.Part.HybridShapeFactory.AddNewControlPoint(ReferenceOnPoint)
' spline.AddControlPoint SplineCtrPt
' ---- Since V5R12
spline.AddPointWithConstraintExplicit ReferenceOnPoint, Nothing, -1, 1, Nothing, 0
Next i
myHBody.AppendHybridShape spline
Wend
PtDoc.Part.Update
Sub LookForNextSpline(ByRef iRang As Integer, ByRef spline As Object, ByRef iValid As Integer, ByRef iOKSpline)
'Limitation number off point per spline
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
iValid = 0
iOKSpline = 0
index = 0
iRang = iRang + 1
Wend
iRang = iRang + 1
'valid point
index = index + 1
Wend
If (index < 2) Then
For i = 1 To index
' ---- Since V5R12
spline.AddPointWithConstraintExplicit ReferenceOnPoint, Nothing, -1, 1#, Nothing, 0#
Next i
spline.SetClosing 0
iOKSpline = 1
' Creates all usable points, splines and loft from the parameter file
'Limitations:
' ============================> NO MORE THAN 50 SPLINEs PER LOFT
Sub CreationLoft()
'Limitations
Const NBMaxSplineParLoft As Integer = 50
'Get CATIA
Dim PtDoc As Object
'Get HybridBody
Dim X1 As Double
Dim Y1 As Double
Dim Z1 As Double
Dim indexSpline As Integer
Dim SplineArray(1 To NBMaxSplineParLoft) As Object
Dim Ref As Object
Dim CtrPt As Object
indexSpline = 1
iValid = 0
iRang = 1
'Analyze file
index = 0
'Remove records before StartLoft
While (iValid <> Cst_iSTARTLoft)
iRang = iRang + 1
Wend
'Search curve defining the loft
While (iValid <> Cst_iEND)
If (indexSpline > NBMaxSplineParLoft) Then
MsgBox "Too many splines for the loft"
iValid = Cst_iEND
LookForNextSpline iRang, SplineArray(indexSpline), iValid, iOKSpline
If (iOKSpline = 1) Then
indexSpline = indexSpline + 1
If (iValid = Cst_iEND) Then
indexSpline = indexSpline - 1
Wend
Wend
' Create the loft
If (indexSpline > 1) Then
Dim Loft As Object
Set Loft = PtDoc.Part.HybridShapeFactory.AddNewLoft
Dim LocalRefSpline As Object
Dim SectionLoft As Object
For i = 1 To indexSpline
Set LocalRefSpline = PtDoc.Part.CreateReferenceFromGeometry(SplineArray(i))
' Set SectionLoft = PtDoc.Part.HybridShapeFactory.AddNewLoftSection(LocalRefSpline, 1)
' Loft.AddSection SectionLoft
' ---- Since V5R12
Loft.AddSectionToLoft LocalRefSpline, 1, Nothing
Next i
myHBody.AppendHybridShape Loft
' Model update
PtDoc.Part.Update
'Main program
Sub Main()
'Get the type of operations to do:
' Points --> 1
' Splines + Points --> 2
' Loft + Splines + Points --> 3
Dim TypeFile As Integer
TypeFile = GetTypeFile
' V5R12 - Create dedicate opneBody for created geometry
'Get CATIA
Dim PtDoc As Object
' Create Open body
Set myHBody = PtDoc.Part.HybridBodies.Add()
Set referencebody = PtDoc.Part.CreateReferenceFromObject(myHBody)
PtDoc.Part.HybridShapeFactory.ChangeFeatureName referencebody, "GeometryFromExcel"
If TypeFile = 1 Then
CreationPoint
ElseIf TypeFile = 2 Then
CreationSpline
ElseIf TypeFile = 3 Then
CreationLoft
Cordialement.
Mounssif
Monsrhf- timide
J'ai testé la macro en R23, elle fonctionne sans problème.
Le problème doit plutôt venir des valeurs décimales dans votre tableau : il faut des virgules et pas des points.
J'ai essayé avec 100.0056 et obtenu la même erreur que vous.
Faites le test avec que des valeurs entières et ensuite avec des virgules comme séparateur de décimal.
Vous aviez raison! J'ai remplacé le point par des virgules et ceci marcha sans problème. Merci beaucoup pour votre aide.
Cordialement.
Mounssif
Cordialement.
Mounssif
Monsrhf- timide
» Comment creer une multitude de spheres a partie de points de centre d un fichier Excel ?
» Problème importation blueprint
» Importation outil - catscript
» Séparation de 2 composants après importation
» astuce - macros liée au drafting
