Le Deal du moment :
Tablette 11″ Xiaomi- Mi Pad 6 global version ...
224.97 €
macro catia V5
macro catia V5 Empty macro catia V5
Message par wassimo Mar 1 Nov 2016 - 11:23
Hi there,
I want to create a macro in catia v5 that colored the operation of Part Design, for example :
when you make a "split" the operation will be colored automatically by a defined color.
There is someone who can help me ?
wassimo
macro catia V5 Empty Re: macro catia V5
Message par Guss_ Ven 18 Nov 2016 - 11:57
Hi,
In your example, when you make a "split" it is by using the tool to split or by using a macro that automatically split ?
You want to color the faces generated by the operation ? At what time you want to run the macro ?
Message par lumpazepfel Dim 20 Nov 2016 - 19:18
Hi,
Here an example of code witch color pad and split.
you can add all other shapes you use in your parts.
'vbscript
Dim oselection 'As Selection
set oselection = CATIA.ActiveDocument.Selection
oselection.Search "Name=*Pad*,all"
Dim Kolor 'As VisPropertySet
Set Kolor = oselection.VisProperties
Kolor.SetRealColor 10, 10, 200, 0
oselection.clear
oselection.Search "Name=*Split*,all"
Kolor.SetRealColor 255,255, 10, 0
