macro catia V5
macro catia V5
Hi there,
I want to create a macro in catia v5 that colored the operation of Part Design, for example :
when you make a "split" the operation will be colored automatically by a defined color.
There is someone who can help me ?
wassimo- timide
Re: macro catia V5
Hi,
In your example, when you make a "split" it is by using the tool to split or by using a macro that automatically split ?
You want to color the faces generated by the operation ? At what time you want to run the macro ?
Re: macro catia V5
Hi,
Here an example of code witch color pad and split.
you can add all other shapes you use in your parts.
'vbscript
Dim oselection 'As Selection
set oselection = CATIA.ActiveDocument.Selection
oselection.Search "Name=*Pad*,all"
Dim Kolor 'As VisPropertySet
Set Kolor = oselection.VisProperties
Kolor.SetRealColor 10, 10, 200, 0
oselection.clear
oselection.Search "Name=*Split*,all"
Kolor.SetRealColor 255,255, 10, 0
» Macro Catia v5 r27
» Macro Excel Catia
» Macro dans catia inertie
» Problème Macro Catia V5R18
» Macro CATIA vers Excel
» Macro Excel Catia
